CB will not Transmit?
Have had my Ultra for some time... actually, took the CB antenna off - but decided to put it back on (yes it says CB on the bottom) got out my manual... pretty straight forward.. CB, ON - channel 17, on screen next to HD is square with CB in it... PPT - hear a 'Beep' that box does NOT turn white, as manual shows When Transmitting??? tried several channels,,,, can not hear or seem to transmit. Call the Dealer,, verified I have 1.19.2 update... was told current update is .19.1 NO 1 in front???
Searched here but did not find anything...
Has anyone else had an issue with CB NOT transmitting OR am I missing something??
BTW - everything else on the Boom seems to work just fine....
Vox and Intercom work just fine,, blue tooth IPhone works just fine.
also when I push the 'squelch' I can see the bars on the screen go up or down but I can not hear anything???
Yes, its a rushmore - thought I would get some feedback here before I did the 25 mile ride to the dealer for the software up grade
while sitting in my driveway, I used the Bluetooth, IPhone to call my dealer - just to check that out - worked just fine
As far as software goes, you should be able to do that yourself. The latest and greatest is on HD's download page. Despite what the dealer may say, the latest is 1.19.2.
http://www.harley-davidson.com/conte...downloads.html
I don't have much confidence that the software update will fix the issue, however perhaps going through the motion will reset something and it work.
Completely understand. Have seen the same thing happen on a friend's Rushmore TK. He had to have the CB module replaced.
Dealer says latest software upgrade does NOT have the 1 in front???? are I think that what I heard,,,,now, not so sure, lol
The squelch button is the PTT button. Up or down changes the squelch, straight in keys the mic. Are you using the correct button?
