2014+ Touring Models This Section Is For Rushmore/2014+ Touring Models Only
Passenger peg delete
Old 05-14-2016, 08:25 PM
rvdoc's Avatar
rvdoc
rvdoc is offline
Default Passenger peg delete
Does Harley or anyone else make a cover plate or something on that sort to cover the 4 holes where the passenger pegs were?
Old 05-14-2016, 08:30 PM
pacemakertom's Avatar
pacemakertom
pacemakertom is offline
They sell different size plugs that slip into the holes making them less obvious.
Tom
rvdoc (05-14-2016)
Old 05-14-2016, 08:31 PM
rjjj629's Avatar
rjjj629
rjjj629 is offline
nope
most suggest plugging them with plastic caps, silicone rtv, or just putting plain black bolts in the holes.
the rtv worked for me
rvdoc (05-14-2016)
Old 05-14-2016, 08:35 PM
perki48's Avatar
perki48
perki48 is offline
Received 4,077 Likes on 1,906 Posts
Many Harley models come with plugs in the unused holes. Models with forward controls have the Mid holes plugged. These should work for you.
Old 05-14-2016, 09:04 PM
jdw1's Avatar
jdw1
jdw1 is offline
Subscribing
Old 05-14-2016, 09:41 PM
rvdoc's Avatar
rvdoc
rvdoc is offline
Menards. Christmas tree type plugs. Used 5/16 plugs. The hole is 3/8 but the plugs are for a bored hole not threaded. 5/16 fits real snug. Squeezed some silicone in the hole, lube always helps, made them slip in easier. Tapped in lightly with a punch.
Old 05-15-2016, 05:20 PM
Casper's Avatar
Casper
Casper is offline
My local Lowes sells a plastic plug in different sizes. They have small plastic teeth on the that grab the holes, they are removable. I used them on a tour pack before installing a backrest...take a bolt with you and find the correct size, slips right in...
Old 05-16-2016, 03:32 PM
Dr. Tiki's Avatar
Dr. Tiki
Dr. Tiki is offline
I removed my passenger pegs on my street Glide. I think it's Harley, but someone does sell a chrome plate that can over the holes in the frame. I didn't care for it so I just used the plastic plugs mentioned above that I got from Lowes.
Old 05-16-2016, 05:23 PM
caberto's Avatar
caberto
caberto is offline
As many have stated already... Plugs are your friend, from Harley, Lowes, wherever.
Old 05-16-2016, 06:32 PM
2807's Avatar
2807
2807 is offline
These are about $1 each from the dealer. Multiple sizes available.
Had them on many bikes to plug the removed peg holes.
Quick Reply: Passenger peg delete
