2014-2023 Touring Models This Section Is For Rushmore/2014-2023 Touring Models
103 High output
Old 05-24-2016, 07:36 AM
Ahhnuld's Avatar
Ahhnuld
Ahhnuld is offline
Default 103 High output
So I am curious and have not seen specific information as to what exactly makes this 103 build a "High output" motor. What is it? Bigger cams? compression ratio? Better HP and TQ specs from the factory?
Old 05-24-2016, 07:41 AM
EasternSP's Avatar
EasternSP
EasternSP is offline
Received 21,825 Likes on 8,403 Posts
I read somewhere that the compression ratio is 10.2:1.
Don't know what the stock hp/tq is but I will find out in a few weeks when I have mine dyno tuned.
Old 05-24-2016, 07:42 AM
'05Train's Avatar
'05Train
'05Train is offline
Higher compression and different cams.
Ahhnuld (05-24-2016)
Old 05-24-2016, 07:48 AM
Ahhnuld's Avatar
Ahhnuld
Ahhnuld is offline
Any idea what the comparison is from stock? Are they SE cams?
Old 05-24-2016, 08:07 AM
'05Train's Avatar
'05Train
'05Train is offline
Compression is listed by model on Harley's website. "S/E" doesn't really mean anything as it's just a marketing term. The cams are similar to the 255s, but pull much better at higher RPMs than any 255 I've ever ridden.
Old 05-24-2016, 08:26 AM
jclax01's Avatar
jclax01
jclax01 is offline
only on the HO 103 twin cooled. The air cooled 103 HO is like 9.5 or something around there.
Old 05-24-2016, 08:27 AM
jclax01's Avatar
jclax01
jclax01 is offline
Bad *** and IMO, the best Harley motor ever from the factory.
Old 05-24-2016, 08:35 AM
Sunnyday91360's Avatar
Sunnyday91360
Sunnyday91360 is offline
Not much difference in compression, air cooled 9.7 and wethead 10.0 basically the cams and some head work make it an HO.
Old 05-24-2016, 09:29 AM
Ahhnuld's Avatar
Ahhnuld
Ahhnuld is offline
Thanks everyone. I am more familiar with the Andrews cams for comparison, which is why I asked about the HD cam versions.
Old 05-24-2016, 10:17 AM
bmaier's Avatar
bmaier
bmaier is offline
Moco literature states 50% increase from new air cleaner design and 50% from cam change.
intake with 30% more airflow and cams with a little more duration and lift .211" vs .198" than 13 and earlier cams, similar to a SE-255 but 4 deg later and much less lift .255"
Quick Reply: 103 High output
