coolant from over flow 2016 FLTRU
At 1000 miles I stopped and the coolant was pouring out the over flow the tank was low . After today's ride there is a small amount of coolant showing . I think its a matter of air in the system. I don't have have coolant and i'm thinking of topping the system off with water. I read the topics about collant and have a cross a over part number for harley coolant that is available near by.Would there be a warrant issues getting coolant that is compatible?
I agree with tpcowfish, call the dealer. After this incident do as brewmany said and use the Peak Global Lifetime coolant or HD Coolant. In any case, the ONLY time you'd want to put water in there is if you have no OTHER choice to get you to a safe place or repair center, and even then you'd want to use distilled water. And after that you'd want to flush everything out of the system and replace with a proper coolant.
I don't have the manual in front of me, but I do recall reading that the water has to be de-ionized. Looking up the difference between de-ionized and distilled, distilled is a boiling process while de-ionized is more at a filtering process. Distilled water is purer than de-ionized water.
I just talked with service department they said I could bring the bike to them for coolant or I could add the global life time coolant with no problem with warrant. The dealer said even with no coolant not showing isn't that bad if there are no warring lights. I'm going to monitor the coolant my self and hope its a one time thing. Thank you for the replys.
It also gives you a trial for a future warranty issue.
