2014-2023 Touring Models This Section Is For Rushmore/2014-2023 Touring Models
Alloy art led turn signal issue
Old 06-22-2016, 04:46 PM
jcmer22's Avatar
jcmer22
jcmer22 is offline
Default Alloy art led turn signal issue
I installed these:
http://www.revzilla.com/motorcycle/a...6#overview_tab
Alloy art led front turn signals and I wired them so they'd flash on turn signal. They're only 2 wire so I lost the day time running lights which I'm fine with. Now the issue is they don't rapidly blink at the physical blinker but the light on the dash blinks like crazy. Is there a specific load equalizer I can use to fix this?
2016 street glide
Old 06-22-2016, 07:15 PM
24v's Avatar
24v
24v is offline
Turn your flashers on for a little bit. It should correct itself.
Old 06-22-2016, 08:09 PM
jcmer22's Avatar
jcmer22
jcmer22 is offline
Just tried this for quite awhile but nothing changed. The dash flasher in the gauge still goes crazy. How long should I leave them flashing?
Old 06-22-2016, 08:10 PM
pswomack's Avatar
pswomack
pswomack is offline
Hook up your battery tender, turn Ignition switch on, turn on 4 way flashers for a minimum of 5 minutes, the blinkers should flash correctly after the BCM relearns for LED lights.
Old 06-23-2016, 06:28 AM
24v's Avatar
24v
24v is offline
Mine fixed itself in less than a minute. Just turned the key on, hit the flashers and left them on for 30 seconds or so, then turned them off and it was all good.
Old 06-23-2016, 11:06 AM
jcmer22's Avatar
jcmer22
jcmer22 is offline
Thanks for the input I'll try that tonight
Old 06-23-2016, 02:43 PM
jcmer22's Avatar
jcmer22
jcmer22 is offline
I just tried this and I'm still having the issue. The blinkers blink at normal speed. However the signal in the gauge on the inner fairing blinks rapidly.
Is there a sequence for install of the turn signals? I've disconnected the battery and nothing changed?
On install I did not disconnect the battery, just plugged them in and walked away.
Old 06-23-2016, 05:26 PM
jcmer22's Avatar
jcmer22
jcmer22 is offline
Got it straightened out
Old 06-23-2016, 06:20 PM
pswomack's Avatar
pswomack
pswomack is offline
What did you have to do?
Old 06-23-2016, 08:01 PM
jcmer22's Avatar
jcmer22
jcmer22 is offline
I found a post on here describing how to make the bike learn there's led's and only the right blinker was working properly so instead I:
Started the bike
Turn the hazards on
Let it idle for 4-5 min
Turned the ignition off while leaving the hazards on
Turned the ignition on and then turned hazards off
Turned ignition off and then back on
Both Turn signals work perfect now,
Quick Reply: Alloy art led turn signal issue
