Accessory Switches
Not sure what you are trying to wire up, but I used the HD accessory switch that mounts on the clutch or brake lever bracket. You can get 3 switches. I use them for heated seat, driving lights, and LED accent lights.
Just another option.....
Housing:
http://www.harley-davidson.com/store/auxiliary-accessory-switch-housing-kit-
Switches:
http://www.harley-davidson.com/store/auxiliary-on-off-switch-kit
Housing:
Switches:
58sniper (07-21-2016)
http://www.harley-davidson.com/store...11-71400106--1
Here is a link to the harness required (left side cover) and the switches to replace the blanks.
I just added these and used one of them to switch a pair of very bright LED lights mounted on the engine guards, provides you with a connection for a load greater than 2 amps and a connection for an accessory less than (2) amps, unless you add a relay to the less than wiring.
Yea saw those in the P&A catalog. I'm wiring up accent lighting but really wanted a clean install using the location in that lower fairing so I wouldnt have to deal with running wiring up through the bar.
I wanted the blanks to look like the lighted ones on the left so I bought the cluster and did some mods to it and plugged it in and all lit up they are all hot now. It is already wired for it. It just comes plugged into the blanks
HD does not make a set of switches for the right side
I did this on a 2014 ultra classic
Yeah they do, it's a CVO switch pack that has the saddlebags lock/unlock switch and 2 faux buttons.
71400033. It's $68. It's not listed in the Parts catalog.
Gonna use the one I have to hook up to a garage door opener, as it's a momentary switch.
