CAMS - SE259 vs Andrews 57H
Hello fellow Harley owners,
I own a 2015 RGS with an SE Air cleaner, Rinehart true duals with the 4" slip ons and the SEPST. After much research I am leaning towards the Andrews 57H cams but my local dealer is recommending the SE259 cams. I believe my current add ons are pretty standard so there's likely some real world numbers floating around for each cams.
My apologies if this has been answered before. I have read through the various cam threads for hours but haven't seen too many people using the SE259 without doing head or piston work.
My '15 Limited Low has the 57s, K&N filter in stock housing, V&H Power Duals and Twin Slash Round muffles.... got 84/98 with a canned tune. Others I've seen with a good tune add maybe 5 to each side.
One word of caution.... the 57 is a noisy cam. Not top end noise, intake reversion noise. That's why I kept the stock AC housing, the sound was too much. Sounds like the butterfly klacking open & closed, but it's not the butterfly.
For ROCKOUT information & purchasing please click the LINKS below...
__________________
NO, they DON'T all do that!
Also on amazon.com...
Received 1,934 Likes
The 204 is a drop in and will even out torque throughout the RPM band,, yes, taking some torque away from lower RPM ranges in the process. The result of the simple 204 install will be a slight reduction in your stump pulling low RPM torque in exchange for meaningful acceleration in 6th gear and a beautiful sounding lope at idle. You'll be in the cam's optimal range at RPM's above 2800.
If you're a rider who likes to lug his engine, stay away from the 204. If up-shifting at 3 grand and above is your thing, you'll be a happy camper on this cam.
BTW, I have the same intake and SEPST as you. The SEPST has a map specific to the 204, just so you know.
The decision depends on :
1- Has your bike been tuned properly? Most tuned Rushmore pipes/AC ~105 TQ 85 HP ±3
2- How you ride-
How many times do you hit the rev limiter in a normal ride?
Do you spend most of your time below 3500 RPM?
Do you prefer to stay low (1500-3000) mid (3000-4500) or high (4500-6000)
Look at dyno graphs from bikes with the mods you are considering to get a glimpse of what the WOT curves look like, and decide if they match your riding style.
2- How you ride-
2- How you ride-
2- How you ride-
