2014-2023 Touring Models This Section Is For Rushmore/2014-2023 Touring Models
Adding King Tour Pak (with lights) to a Special
Old 07-13-2016, 05:57 PM
JimTJr's Avatar
JimTJr
JimTJr is offline
I'm prepared to put a new plug on the tour pak side, no biggie. The dealer has the plug and pins in stock, just have to cut wires, solder the pins on and repin the plug to fit the Rushmore.
Old 07-28-2016, 03:15 PM
silveradoman2's Avatar
silveradoman2
silveradoman2 is offline
Thumbs up
Originally Posted by JimTJr
I just bought a TP off a 2010 Ultra, do our bikes have the plug on the MC side already there? (Just did a thread asking this,, right before I saw this thread)
Here is my purchase, 600.00! I'm happy with it, (My son will paint it this winter, but black on Amber Whiskey looks ok for now,, especially with the vivid black fairing inner on the front.
Thank you for the pictures. I have been looking for a Tour pak for my 15 RGS. I have a black engine guard, black bars, black levers, mirrors and black saddlebag guards. I was wondering what a black tour pak would look like.
Old 07-28-2016, 09:31 PM
JimTJr's Avatar
JimTJr
JimTJr is offline
NO problem Silveradoman, I actually think it looks just fine that way, (the black inner, flows to the tour pack) However I will do some painting on it this winter. It will look better color matched.
Old 07-29-2016, 10:40 AM
PSRumors's Avatar
PSRumors
PSRumors is offline
Are you hooking up the passenger communications portion of the TP?
That's my next project
Old 09-04-2016, 09:40 PM
Robtarra39's Avatar
Robtarra39
Robtarra39 is offline
Originally Posted by PSRumors
Afraid not.
For the lights, I am using NAMZ y adapter PN NTP-CB01. It plugs in under the seat between the main harness and the taillights. Not sure this is compatible with your lights or not.
http://www.namzcustomcycleproducts.c...harnesses.html
For antennas I am having to replace the amfm and cb cables that run from the fairing to under the seat with the RGU cables, these will reach to the tour pak.
As for speakers, I'm not using those at this time so I have not looked at a harness yet.
When I am finished everything will plug in under the backrest like factory.
I am in the middle of doing the same, i have the tour pak, and the wrap around light is due in this week, the light comes with no wiring, so is the Namz adapter the only wring i need to go from under the seat to the plug on the back of the light, what about the side lights on the tour pack, how are those connected?
Old 09-04-2016, 09:51 PM
timbo141's Avatar
timbo141
timbo141 is offline
You will also need the harness that goes from the namz to the light itself. HD part # 69200131 includes all of the harnesses (side marker ones too)
Also the AM/FM extension cable is included in the above harness.
Don't forget the screws HD part # 10200133 (8)
Here is a link to the tour pak parts list:
http://partsfinder.onlinemicrofiche....=81&c=0&d=2016 FLHTK ELECTRA GLIDE ULTRA LIMITED (KEL) TOUR-PAK - LAMPS AND SPEAKER HOUSINGS
The following 4 users liked this post by timbo141:
BrownSanta (10-28-2016), dannyb-SGS (10-29-2016), Lu (07-13-2017), Robtarra39 (09-18-2016)
Old 09-05-2016, 01:20 PM
silveradoman2
Very nice
Old 09-18-2016, 07:40 PM
Robtarra39's Avatar
Robtarra39
The tour pak is wired up and lights work. Just waiting on the local Harley shop to get the AM/FM cable in and I'll have full functionality. I am also using the Custom Dynamics Magic Strobes and it strobes the light right in sync with the others
I am not sure if I am going to add speaker pods so I ran the harness through the floor of the tour pak. The QD mount makes for a great place to run wire though I will need to get some trim to keep the wire from chaffing on the edge.
Rather simple install really...just need to get the liner to finish it off.
I also want to get a set of the side marker light to get rid of the chrome trim.
PSRumours with your post i was able to get mine done and thank you for that, waiting on the harness and NAMZ connector that are on order and i am done with mock up, then off to paint, would you have a pic of the harness the NAMZ connects to under the seat, i looked and saw a few there
Attached Thumbnails Adding King Tour Pak (with lights) to a Special-img_4301.jpg   Adding King Tour Pak (with lights) to a Special-img_4300.jpg
Old 09-18-2016, 10:41 PM
timbo141's Avatar
timbo141
timbo141 is offline
There are two connections under the seat on the left side, the Namz is color coded to match the black one. The other one is cream colored.
Old 09-19-2016, 12:04 AM
PSRumors's Avatar
PSRumors
PSRumors is offline
Looks good. Like stated above, the black connector is what you want. It should be self evident when you get the NAMZ harness. None the less, I'll try to remember to pop a photo tomorrow.
The following 2 users liked this post by PSRumors:
dannyb-SGS (10-29-2016), Robtarra39 (09-19-2016)
Quick Reply: Adding King Tour Pak (with lights) to a Special
