2014-2023 Touring Models This Section Is For Rushmore/2014-2023 Touring Models
LED's flashing at different rate
Old 11-18-2016, 11:33 AM
merlin41's Avatar
merlin41
merlin41 is offline
Default LED's flashing at different rate
I like having a lot of light in the back of the bike. I tend to stick with Harley accessories so I added the stick on saddlebag lights (PN 67800241A) and the "keystone" lights on the bag supports (PN 67800589). When I turn the turn signal on, the LED's blink at different times. It's more than just one turning on faster than the other. They are not in sync after a few blinks. I'm looking for input from someone who has this same combination on their bike. Do you see the same thing happening? (This is not the "fast blinking" of the green arrow on the dash - that is OK.) Thanks for any help.
Old 11-18-2016, 11:56 AM
2goldens's Avatar
2goldens
2goldens is offline
Try putting the 4 way flashers on for a few minutes to sync things.
Old 11-18-2016, 12:35 PM
Baeseman1's Avatar
Baeseman1
Baeseman1 is offline
I have the Harley Electra-Glo stick on bag lights & the Stealth under bag lights. (In addition to the CD Fillerz & BAL tail light.)
I've never had an issue with them flashing at a different rate.
Old 11-18-2016, 12:37 PM
Heloguy's Avatar
Heloguy
Heloguy is offline
This should fix your problem. It is what is recommended by Custom Dynamics if you have this issue with their turn signals. I let my flashers run for about 4 minutes, and everything is great.
Old 11-18-2016, 12:38 PM
merlin41's Avatar
merlin41
merlin41 is offline
Thanks. I'll try turning the flashers on tonight to see if it makes any difference. I did that when I added the CD Ringz on the front.
Old 11-18-2016, 03:23 PM
OldPhat's Avatar
OldPhat
OldPhat is offline
I have the exact setup as you, put the flashers for a minute or so.
Then ride and use the turn signals a few times should do it for you.
JHC210
Milwaukee Eight (M8)
21
03-15-2019 08:48 AM
billbrummett
10-31-2018 03:08 PM
flhchaz
38
11-29-2017 06:28 PM
Buelligan666
03-20-2015 09:26 PM
valter
11-28-2011 06:40 PM
Quick Reply: LED's flashing at different rate
