TGS 32310-08 install
For the life of me I cannot seem to find an "all-in-one" post of key steps or points as to what goes into using the TGS 32310-08 on a Rushmore Touring bike.
Let me state what I think I know, then I ask of the forum to fill in my gaps (or direct me to the post I missed):
- The 32310-08 kit does not have the correct male connector. Must purchase a molex socket 72414-07BK.
- The 32310-08 kit does not have the correct pins. Must purchase 6 x 72168-07 pins. This point has been argued as to whether the Rushmore pins are different, or at least will work.
- A wiring scheme for the new connection is below. Is it correct?:
yellow conduit:
black to cavity 1
white to cavity 2
red to cavity 3
black conduit:
black to cavity 4
white to cavity 5
red to cavity 6
- Some have taken the TGS to their local HD for crimping the new connectors. Is the necessary crimping tool a specialty item?
What other key items have I missed? Some have reused the stock molex connector. Some have used the pins that came with the kit.
****Edit: Looks like this post mostly explains what I need. On thing left is to verify that the connectors are indeed different, as well as the inexpensive tool for crimping.
https://www.hdforums.com/forum/new-r...l-problem.html
Further, Molex cites that the female connector part above is obsolete and replaced with 33012-3003.
yellow conduit:
black to cavity 1
white to cavity 2
red to cavity 3
black conduit:
black to cavity 4
white to cavity 5
red to cavity 6
Last edited by RomeoTango; 02-27-2017 at 02:54 PM. Reason: Found the post I needed
pennetta
07-20-2009 08:00 PM
