14" Yaffee Monkey Bars with heated grips
These are 12" with heated grips. I found it much easier to strip the sheathing off all the wires so I could pull the switch and both heated grips wires. New heated grips come with an 8" extention. I didn't have to use it, so you might need to extend it. I had to get switch extentions for my RK
I don't think know, mine came with my Chrome and Rubber heated grips. It has a white plastic connector one each end, male and female. It would plug into the center of your heated grip and the main grip connector plug into that. if you need one, I will sell you mine I didn't need for $10 shipped. Here is a tip. The power wire runs out the side of the left grip, if you are going to hide the wires, I ran mine through the switch covers but you will need to notch one or both sides to allow for the wire, then they go under the switch housing and into the bars.
JaboIam
2014-2023 Touring Models
22
12-18-2015 11:46 AM
