2014-2023 Touring Models This Section Is For Rushmore/2014-2023 Touring Models
Opinion on tire air pressure for 2016 SGS
Old 04-23-2017, 02:33 PM
slapshot12's Avatar
slapshot12
slapshot12 is offline
I run what the book says. I've tried a little over and have had the tires cup on both touring bikes.
  #32
Old 04-23-2017, 10:18 PM
K Melancon's Avatar
K Melancon
K Melancon is offline
38 front - 41 rear. Check often and never have cupping. I get 25,000 out a set
  #33
Old 04-24-2017, 02:05 AM
Kacowboy's Avatar
Kacowboy
Kacowboy is offline
What I have recently seen is that Harley and Michelin differ from what they list for a 2014 RK. Harley says 36 frt and 40 rear. Michelin says 35 frt and 39.2 rear.
  #34
Old 04-24-2017, 07:23 AM
jpooch00's Avatar
jpooch00
jpooch00 is offline
39.2 PSI? Now I've heard everything!
  #35
Old 04-25-2017, 01:18 AM
Kacowboy's Avatar
Kacowboy
Kacowboy is offline
That was my thinking when I read it on the Michelin website. How many people actually use a gauge that measures tenths.
  #36
Old 04-25-2017, 04:50 AM
GalvTexGuy's Avatar
GalvTexGuy
GalvTexGuy is offline
Received 3,949 Likes on 2,169 Posts
Originally Posted by CSMHOG
This forum is full of useful information but it's also a venue of bad information. Be careful what you take away from it. I use the tire pressure as recommended by the OEM, they've paid researcheres to study what pressure would be ideal for safe operation / handling of their vehicle.
Regarding the sidewall markings. North American Load & Pressure Markings
The maximum load and maximum inflation pressure are required to be branded on the sidewall of tires sold in North America.
Tire pressures are normally measured in "pounds per square inch" (psi), Kilopascals (kPa), or bars of pressure (bars). At sea level, Earth's atmosphere is pressing against the surface with a force of 1 kilogram per square centimeter. This pressure is identified as one "bar," and is equal to 100 Kilopascals or 14.7 pounds per square inch of pressure.
Note: 1 psi = 6.895 kPa
A 225/50R16 92V-sized tire as used in our example would have its maximum load and maximum tire inflation pressure typically presented on the sidewall as follows:
North American Codes Only
Max. Load 630 kg (1389 Lbs)
Max. Pressure 300 kPa (44 Psi)
This branding identifies that tires in the 225/50R16 92V size used in this example must be capable of, and be rated to carry 630 kg (1,389 pounds). Additionally it identifies that the maximum tire inflation pressure for this tire is 300 kPa (44 psi).
It is important to note that the maximum load is rated at an industry specified tire inflation pressure that is often lower then the tire's absolute maximum tire pressure. The tire pressures used to determine the maximum load the tire is rated to carry is based on the sizing system industry standards applied to the tire.
Sizing System Tire Load Range Load Pressure
P-metric Light Load
Standard Load
Extra Load 35 psi
35 psi
41 psi
Euro-metric Standard
Reinforced or Extra Load 36 psi
42 psi
However, the tire's maximum inflation pressure may be greater, such as 300 kPa (44 psi) in this example or even 350 kPa (51 psi). This is done to accommodate the vehicle manufacturer's desire to tune the tires' high-speed capability, handling qualities and/or rolling resistance to better suit the vehicle.
It is important that owners consult their vehicle's tire information placard (usually found on the driver's door or doorjamb) or their owner's manual for the recommended tire pressures for their vehicle's driving conditions.
Nice copy and paste. You could have just posted the link.
  #37
Old 04-25-2017, 07:24 AM
jpooch00's Avatar
jpooch00
jpooch00 is offline
Maybe Michelin & the MOCO will team up to come out with a super-mega-accurate digital tire pressure gauge that measures all the way down to thousandths of a PSI. Only $249.99 (rechargeable batteries & USB cable included. Show-chrome-plated billet schrader valve air chuck, or in MOCO-speak "The tire valve stem to pressure gauge hose interface assembly", must be purchased separately at additional cost, natch').
Yeah, I NEED one of those! Hopefully they'll fast-track this project.
Kacowboy (04-27-2017)
  #38
Old 04-26-2017, 07:50 AM
JimTJr's Avatar
JimTJr
JimTJr is offline
You're a CUBS fan, why would we listen to you,,,, GO CARDS!
Originally Posted by Rob175
Again.... the sidewall ONLY SHOWS THE MAXIMUM TIRE PRESSURE FOR THE TIRE. It doesn't matter what brand or size of tire you put on THE CORRECT PRESSURE FOR THE VEHICLE IS MARKED ON THE VEHICLE or in the manual.
Seriously, find a tire expert or ask a trusted mechanic and you'll learn. If you don't inflate properly you risk problems ....... (stability, control, handling, tire wear, fuel mileage etc etc etc)...... find and expert and report back to confirm what I'm saying.
(J/K,,, ) Although I have ran my vehicles (besides my F350 truck) at max or close to max all the time to include my Bike) No ill handling effects felt, It's presumed that if the bike is loaded, 2 up it should be at max. I doubt that is the "Max" you can do before bead blow out,,, or what ever you're claiming... It's all in how you read it I suppose.
  #39
Old 04-26-2017, 10:26 AM
oakmossy's Avatar
oakmossy
oakmossy is offline
36 front,,40 rear,,,perfect.
Atlaska
06-17-2015 12:26 PM
WVDevil
Wheels/Tires
05-19-2015 09:59 AM
S.D.M.F
10-14-2012 04:07 PM
kjunguy
06-08-2007 08:48 PM
pyro
Ironhead
13
11-20-2006 01:12 PM
Quick Reply: Opinion on tire air pressure for 2016 SGS
