TORX size to remove engine guard on 2014 StreetGlide
OK - I called my local HD shop. Here are the sizes for the 2014 Street Glide:
For the lower frame bolts- Torx 45
For the middle frame bolt 1/4 in HEX
I highly recommend both tools as sockets so you can use a ratchet/breaker bar to get these darn things loose and tight again.
Happy wrenching guys.
Z.
Z.
I just double checked mine and while the T45 fits it is loose the T47 fits nice and tight
with no slop ... is it possible the MOCO changed the size from 14 to 16 I guess BUT I HIGHLY doubt it..
if you got them out already great BUT Torx are very easy to strip so don't take a chance also the MOCO generally uses the white lock tight, that crap is a BITCH and a little heat goes a long way to getting them out
