I don't care what you say, checking and putting air in MC tires is a pain in the ***! I bought these awhile back and plan on installing them when I get new tires put on. They look well made, steel construction with two nuts to secure them inside the rim. Purchased them from Veteran Tire and Rubber on line. Anyone out there using these?
Yep! Had one put on my back tire when I picked up a few screws. These came in a 2 pack. Saving the other one for when I get my front tire changed out.
A huge help!
Mine are CVO stems 90 degrees. Those appear to be 45 is that why they needed rotated? Either way a big help for air pressure check.
will the CVO stems fit on a regular tourer? i have a 2013 flhtk i want to put some on. i think i asked about it last time i had tires switched out and the tech said they wouldn't fit. found it odd.
