2014-2023 Touring Models This Section Is For Rushmore/2014-2023 Touring Models
iphone help
Old 04-29-2017, 04:34 AM
Drtumolo's Avatar
Drtumolo
Drtumolo is offline
Default iphone help
I have a 2016 street glide special and I am trying to stream Pandora from my iPhone 5s while charging with USB cable in storage compartment. Can't get it to stream music. What am I doing wrong
Old 04-29-2017, 07:20 AM
chopper_man's Avatar
chopper_man
chopper_man is offline
Received 1,603 Likes on 953 Posts
I have/had the same issue. Mine won't stream via BT when plugged in to the on-board cable. If I use a 12v adapter in my power port it will charge/stream just fine.
Old 04-29-2017, 07:58 AM
Cygnusx51's Avatar
Cygnusx51
Cygnusx51 is offline
Received 1,647 Likes on 1,076 Posts
There's been a few threads on this and I think that when you have pandora streaming and plug it into the USB, it will pause pandora because now the BOOM system is trying to play any media stored on the phone (USB). You'll have to make sure that the pandora app isn't paused after plugging in or after a stop. Also you may have to make sure that the BOOM system is set back to Bluetooth rather than USB under the media section.
Old 04-29-2017, 08:06 AM
JMC22's Avatar
JMC22
JMC22 is offline
I have a 15 SGS, I use my iPhone 6 to play my iTunes or Pandora without any issues via the onboard USB in the storage compartment - Does your iTunes work ok? Have you tried a different USB adaptor?
I would turn the bike on first, then plug in the iPhone - it should automatically connect into it, if not do it via the onboard system.
Old 04-29-2017, 08:45 AM
Roadie13's Avatar
Roadie13
Roadie13 is offline
Received 1,005 Likes on 497 Posts
Yep. If I bluetooth my phone it goes back to whatever was playing after a gas stop or whatever when bike is turned off. If I plug in to the USB the phone defaults to itunes every time the ignition is cycled and I have to manually go into the phone to restart the app and then I'm ok until the next power cycle.
Old 04-29-2017, 08:46 AM
5150northrider's Avatar
5150northrider
5150northrider is offline
After you get the Bluetooth connected and the phone is plugged in go back and shut off anything playing that automatically started on your phone when you plugged it in, the bike will automatically start to try and read the phone every time. After you get that taken care of start the Pandora app then go to the media and select your phone in Bluetooth. I don't care to plug my phone in to keep it charged this way it's to much of a pain and takes forever to get a charged battery. Yes it is nice to maintain the battery but it's easier to skip it and charge later
Old 04-29-2017, 11:38 AM
Cygnusx51's Avatar
Cygnusx51
That's a good point also. For what the portable power banks/chargers cost now, you could always power the phone or charge it from one of those instead. No need to connect it to the bike any other way than Bluetooth to alleviate the issue of having to switch modes and check the app after stops and such.
Old 04-29-2017, 05:01 PM
Drtumolo's Avatar
Drtumolo
Drtumolo is offline
It streams Pandora fine when using BT but stops when I plug the phone in. I will try restarting it to see if that solves the problem
Old 04-30-2017, 10:45 AM
5150northrider
my experience it will try and play any music you have saved on the phone to the memory if you plug it in and you will have to stop that playback every time before you can start streaming Pandora, it's reading the phone like a memory stick! For what it's worth I Bluetooth slacker and haven't ever paid for the satellite radio, the only thing the xm is good for is the weather app in my opinion
sulli
Audio Systems
15
07-20-2020 03:07 PM
smokinfromshootin
06-01-2015 07:58 PM
cdestuck
11
04-17-2015 01:36 AM
Rockrivr1
29
08-04-2014 07:09 PM
Jzabel
09-12-2007 09:04 PM
Quick Reply: iphone help
