I'm gonna burn this MF down... WTF is this noise!?!?
Originally Posted by Steve Helton
Have you checked the oil pressure oil pump may be bad.Thought mine on my 10 was lifters changed them same noise problem was oil pump.
Originally Posted by KrustyKush
My 2016 will do this noise once in awhile. Pretty sure a lifter or two leaks down overnight. The noise lasts no more than one second.
I learned long time ago not to sweat noises that happen on a cold motor. What matters is noises on a hot motor and even most of those are of no account.
What cams? What pushtubes? Readjust the pushtubes. If it's happening more at the end of oil change intervals. Change the primary oil only and listen. Is there any difference. Yes or no. Change the engine oil only is there any differences. Yes or no. If your fed up with it figure it out. Get creative
Originally Posted by hardheaded
there is alot of good suggestions here. hoiw old are the cam chain tensioners ? mine bike makes alittle noise too, but only when cold until they get some oil.
The heavier oil 'should' quiet things some, but OTOH it won't fix any real mechanical issue (if there is one).
