I'm gonna burn this MF down... WTF is this noise!?!?
#51
Any chance you have a worn lifter bore & that one lifter is having trouble getting up to pressure?
If so they make oversize lifters.
For ROCKOUT information & purchasing please click the LINKS below... For all Twin Cams and Evo Big Twins & Sporsters
__________________
NO, they DON'T all do that!
Also on amazon.com...
#52
#53
I recognize the name, not questioning anyone's ability.
I'm just saying when you run out of things it can be, you start looking at things that "can't".
Good luck.
Good luck.
sirrat007 (06-24-2017)
#55
#56
Good luck.
Good luck.
#57
Have you tried using a stethoscope to pin the noise down to a particular area? Stethoscope is not really necessary. When I wrenched cars I would just use a long handled screw driver and hold the handle against my ear to listen for the knock or tapping noise. Sure saved a lot of time that way.
good luck......Mike
good luck......Mike
#58
I have read all the replies and don't believe any one mentions the fuel management. Did you check the fuel management? Just thinking out of the box. Maybe on start up even on what we called "hot engine", the engine is cool enough to trick the computer to believes the engine is cold so it would give a cold start up program and cause the noise.
Good Luck, hope you figure it out...
#59
My oil pump was changed at build also they can be bad from the factory.I tried 2 sets of lifters no help.Oil pump did the trick.
