I'm gonna burn this MF down... WTF is this noise!?!?
This is really pissing me off. Only on startup and only at the end my oil change intervals. Yes, I have rocker lockers installed. Yes, the lifters have been replaced with S&S. Yes, the compensator has been replaced with a Baker unit. No, the primary chain is not overtight in any spots. This is driving me in****ingsane. This is a milder version of it. Sometimes it'll sit and rattle on startup for a solid 4-5 seconds and loud enough to catch the attention of passersby. Any ideas?
What oil are you running? Syn oil is great for a lot of things.... noise isn't one of them.
Try some Spectro 25-60 dino oil, you might be very pleasantly surprised.
For ROCKOUT information & purchasing please click the LINKS below... For all Twin Cams and Evo Big Twins & Sporsters
__________________
NO, they DON'T all do that!
Also on amazon.com...
While his video didn't really show me anything, I can relate to what he is going thru. My 96"2011 FLHR will do the same thing on occasion. Primary chain will rattle/slap loud as hell, other times nothing. Currently running Formula Plus in the primary but gonna try some Spectro next time( also gonna give the Spectro 25w-60 a shot). OH YEAH, it just became an oil thread!!!
I run either HD non-synthetic or Mobil1, it does it with either oil. The lifters were replaced because that's exactly what it sounded like was happening. Still have the exact same noise with S&S lifters that I did with factory. Rocker shaft end play is around .015", spec is no more than .025" so by the book, I'm ok there. I'll check out the shifter issue, but it doesn't seem like that's the problem. I checked my primary cover/cases on the inside when I put the baker compensator on, didn't see any evidence of the chain slapping the cases. This problem is really pissing me off, I just want it gone.
You mentioned the noise was more prominent towards the end of your oil cycle and just before the oil change. Have you checked your oil level before you change? Does the oil level drop any? Oil pressure will drop with lower oil levels. If you bike is consuming oil, via blow by, excessive crankcase pressure or possible another leak somewhere, your lower oil pressure will change many factors in your bike.
Wildon883R (06-06-2017)
