Khrome Werks 2+2 Narrow Sweepers vs HD Reduced Reach
#41
Install instructions are plentiful if you look.
I did have to remove the switch connectors to run the wires internal. I removed the connectors with a sewing machine needle. I didn't know what I really wanted to accomplish so I just stuck the needle in the connector and wiggled it around until the pin can out.
I saw this connector animation after I completed the job. Sure wish I saw it before. Now I know how the connector works.
I used two weed wacker strings to pull through
Thats a lot of wire through those little bars. KW doesnt make it easy with the small holes.
wide glider (01-22-2019)
#42
They say a picture is worth a thousand words....I think the animation showing how to depin the molex plugs is priceless. I have watched numerous YouTube videos which try to explain the process and you see someone with experience unplug the wires with no effort at all. I think this little picture will prove invaluable to any of us swapping handlebars and wiring them internally. Thanks for posting this!
#43
Received 2,084 Likes
#44
I replaced the reduced reach with the 2+2's on my Limited Low.....
I HATED the reduced reach bars, the angle for the grips hurt my wrists.
The 2+2's have a more relaxed angle, a better pull back and I have ridden for 10 hour days with ZERO discomfort. I think you will like them myself!
