Vance and Hines Hi Outputs, love them
I doubt much at all will change if just the V&H Slip On's are added. I doubt a Tuner would be needed either, but I would do a FP3 anyways.
I prepped my "Quiet Baffles" with Acetone, scuffed them up with a green Scotch Pad, and painted them with Hi Temp Header paint before I put them in.
Good Luck
You can and won't need a tuner if you run those although a tuner will make it run much better. The HO's are really designed for bigger inch motors as the CVO's are anyway so you won't loose low end.
tbob (06-23-2017)
have a good low rumble. And my warranty stays in tact.Thanks for the input.
Been off the forum for a while. My 03 Heritage burned up in the Gatlinburg Wildfire in which I miss. But, I have landed a nice low mileage 014 Road King just recently which I plan to enjoy.
I've got the V&H Power Duals, and the 450 High outputs, Stage 1 air cleaner and FP3 to go on my bike. I'm on the fence about changing to the quiet baffles before I even install them. But at 200 bucks on top of what the system already costs, it's a bit hard to justify.
How about a few of you chime in that maybe have quiet baffles and you that don't. Was it worth the extra $200? Is it that much quieter? Would you change them out again if you had it to do over?
My Heritage had the V&H Longshots with baffles which seemed about right. Will my King with the Power Duals and the Hi Output 450's be quieter or louder then that? Thanks a bunch and I will get some pics up when I get it together.
Thanks for the reply. Here is the deal. I bought these V&H mufflers, 16555 Dresser Destroyer OS 450 chrome w/ black tip.
I bought the 21905 quiet baffles which were in your amazon link
Here is the page from V&H which shows the 16555 mufflers that I got and also the matching 21844 quiet baffle http://os450.vanceandhines.com/#titan
Here they are on amazon for $99 each
So, from what I see the 21844 at $99 each looks to be the ones that fit. Am I wrong?? Thank You
Yes, your correct, but we do NOT have the same V&H Slip On's.
I have the 16455 Hi Output V&H Slip On's.
http://products.vanceandhines.com/store/harley/16455/
