2014-2023 Touring Models This Section Is For Rushmore/2014-2023 Touring Models
Is there a way to name a waypoint?
Old 06-22-2017, 10:51 PM
skurtenb's Avatar
skurtenb
skurtenb is offline
Originally Posted by IUOE ROB
There's a program called MotoGoLoco http://www.motogoloco.com/ IIRC some on here have used it and I think you can name the waypoints. I've used it once or twice, never really named the W/P's but it works pretty well.
I agree. I like it a lot better than ride planner. Super easy to use
Old 06-23-2017, 09:22 AM
dh_meyer's Avatar
dh_meyer
dh_meyer is offline
I just tried motogoloco ......... created a route, named a waypoint, but do not see the waypoint name in the gpx file.
Clearly could be a user error on my part, but I've tried multiple times.
If someone knows how to name waypoints with this app, I'm all ears.
Old 06-23-2017, 11:12 AM
Cygnusx51's Avatar
Cygnusx51
Cygnusx51 is offline
Received 1,647 Likes on 1,076 Posts
^ Definitely could be handy, I'm interested also as I may give motogoloco a try next time I want to plan out a ride, just to see the differences between it and Ride Planner.
Old 06-23-2017, 05:39 PM
Grousehunter's Avatar
Grousehunter
Grousehunter is offline
The problem as I see it is the inability of the nav software to allow an "unannounced via point" as Garmin does. When every shaping point is a "waypoint" "distance/time to via " becomes useless. Also the loss of waypoint "names" when past them (that is when the lat/long seems to take over) makes route editing on the fly a real PIA. I really wish: 1. Harley would listen to these ideas, 2. that an online study group or users group could be established (even right here) to just have constructive solutions discussed related to everyday user issues.
chambers j (06-24-2017)
Old 06-24-2017, 08:39 AM
cycle7447's Avatar
cycle7447
cycle7447 is offline
Received 1,696 Likes on 1,029 Posts
Wow - tried Motorgoloco - didn't seem to work for me. I could not add waypoints with going to the map and putting them in. Would not let me type in a via point.
this one seems to help me make my plans. tripplanner.honda.com
Old 06-24-2017, 11:46 AM
Hammz's Avatar
Hammz
Hammz is offline
I've posted many times that I use Route Converter. It's a Freeware/Shareware application that runs as a simple EXE file. It uses Google Maps db (will allow satellite or map views). It allows zooming in tightly enough for accurate waypoint placement. It allows each waypoint to be descriptively named and/or numbered (simply double click on the waypoint to be renamed). It will display route, waypoints, or tracks.
It allows multiple routes in a single GPX file. It allows each route to be named independently, with a different name for the GPX file itself. The 6.5 GT will allow installing a GPX file with multiple routes & then recognizes & runs those routes independently, using the route names (not the GPX file name).
To keep the 6.5 GT on the same route that I make, I set the system to shortest route & make sure I place my waypoints just before or just after each turn (never in the middle of an intersection which allows the 6.5 GT to route you off the intended route) & all avoidance's off.
Here's a screen shot with a route loaded:
Old 06-25-2017, 07:58 AM
Grousehunter
Dave,
Quick question......are you using RouteConverter as a stand alone program to CREATE your routes or are you creating them in another program (BaseCamp for example) and then EDITING in RC?
Thanks.
Old 06-25-2017, 03:16 PM
Hammz's Avatar
Hammz
Hammz is offline
Originally Posted by Grousehunter
Dave,
Thanks.
I actually do both, but the version I load into the bike is always the one saved using Route Converter.
Old 06-25-2017, 08:59 PM
Grousehunter
Thanks.
Old 07-13-2018, 01:51 PM
jgerboc's Avatar
jgerboc
jgerboc is offline
2nd Gear
Im thinking people are forgetting to "Select All' when they import into Boom. I painstakingly created waypoints on a day trip and Boom ignored them. I went back and re-imported the file and made sure to select all and it seems to work.
steveng
Road Trips
04-23-2019 12:04 PM
Ganooch
50
06-28-2015 10:51 AM
KB5
10-23-2014 08:40 PM
mgmmgm
09-08-2014 06:35 PM
monkyman
01-11-2009 08:04 PM
Quick Reply: Is there a way to name a waypoint?
