No "Cat", but still HOT
This^^^^^^^^ I've never ridden a Harley that was not hot in the summer. You may want to look into a Goldwing, my neighbor bought one and raves about how much cooler it is compared to his previous 2013 Limited he had. I told him I'm sure it is cooler but ONLY temperature.......Gramps!!
I had a new 2014 SGS for 6 months, decatted headpipe, a/c, pipes and a PC5 with a canned tune. It was hot
Got a new 2014 FLHTK. Transferred everything over, much better but still on the hot side. The fans would be on at every stoplight in slow traffic, and when I pulled in the garage.
About 16 months ago, I put on a Fuel Moto SS ceramic coated headpipe, and Jackpot slip ons. Fuel Moto sent me a custom map for my PC5. The difference is unbelievable. The fans haven't kicked on since. The Headpipe has less then half the weight of a decatted headpipe. Nothing for heat to hold on to.
The only heat I've ever noticed is the surrounding air and the sun hammering on me.
Engine is factory-stock, other than S&S Premium lifters and "quickie" adjustable push rods that eliminated the valve noise, OEM exhaust & tune.
FWIW, I love mine just the way it is!
That's what I'm hearing. I called Vance and Hines and they said the Power Duals should reduce the heat more than just decatting. I'm willing to try. Very frustrating though.
The lower vents are open. I do have fork deflectors, but I can't imagine that causing all the heat. The deflectors are a must at speeds greater than 70.
This was brought to my attention by the speed shop at a dealer I bought the bike from. Basically the guy scolded me like a child for starving the motor of air and causing an overheating condition.
I would at least try it without the fangs and see if there is an improvement. Other than that, I would run a tuner to cool things down. I don't trust dyno tunes anymore, having had a couple bad ones. I would rather get it to 95% with a tuner than some hack get it wrong on a dyno.
