Wireless Headset Interface Module | Harley-Davidson
#771
I just had WHIM installed on my 2017 Roadglide Ultra. The service guy told me there is a special cable for those not having a CB. We found this out the hard way after the WHIM was installed. If you don't have the right cable, it won't even display linking the headset. I also picked up two HD20s EVO headsets which is what I am debugging now for wind noise. I have the sensitivity levels all the way down but the level of wind noise is still an issue. I have the Lucid half helmet which is lite and comfortable but it may be part of the issue.
#772
1. Over size sponge on the boom mic. I had one from my Cardo that was bigger.
2. I keep the mic right at my lips.
3. My wife wears has to new three-way helmet that can go from half to full face. I had to get creative there. Rather than mount the mic in the faceshield, like we used to, I went for the boom mic. Allows her to position it at her lips and to remove the face guard.
4. I used some beer can aluminum and created a small shield that covers the front of my mic. I have a picture of it in this thread somewhere. It works very good.
We can talk up to 70 without concern. 80 is pushing it.
A couple of times, I have had one of our headsets reconfigure itself, for no reason. I wrote it off to picking up "a stray signal". It immediately corrected itself and we laughed it off.
I've had the WHIM since August and the HD sph-20s as soon as they came out. Took a bit of tweaking but I am very happy with them now.
#773
I spend a lot of time around 80. A little bit of headwind really makes things worse at that speed.
I finally fixed that when I yesterday, where I unplugged the module and re-mounted my trusty old wired headset. Some folks have reported being able to use either, but I couldn't make the wired headset microphone work while the module was plugged in.
#775
I wish I could turn off the vox, but I've not found a way to with the wireless setup. I only use Push to Talk on the wired headset.
I think I will keep the BT headsets for when wife and I ride together. I usually ride slower then.
#776
My wife and I gave up on using intercom via the Boom intercom system; we could not find a vox setting that would work. We shut the Boom intercom off and are using the paired headset intercom system. We have no issues with vox interference and the overall intercom experience is much better. Simply tap the jog dial to initate the intercom. We use all other features of the headset via the Boom system with no issues.
#777
I'm jumping into this thread a little late but I was told that WHIM will not deactivate the wire system but you can either use the wireless bluetooth headset or the wired. Not a combination of both. A rider controls everything whether wired or wireless. Passenger has to be the same as the rider if they want to have functions other than just listening.
#778
Any recommendations as to who I can contact about the WHIM problem of dead wired microphone with 2017 Ultra Limited when the WHIM is connected? Is there a HD MoCo contact? The WHIM is manufactured by Sena, should I contact them? The radio is manufactured by Harmon Cardon, should I contact them? I just want to know if it is a firmware problem that they are working on, or if I have a defective part somewhere, possibly including the radio itself.
#779
Tell that dealer to get your bike, and its COMMs working as they should!
HeratageJim (03-20-2018)
#780
