helmet theft increases??
#61
I found a post on this forum a few years ago that someone had used a certain Master combination lock to secure their helmet. It's the model 630D. The shackle is just big enough so that when you lock it around the brake or clutch lever it can't be pulled off due to the **** at the end of the lever. I just set my helmet onto the mirror and run the shackle through the d-ring and lock it to the brake lever. This is providing of course that your bike is using the stock brake and clutch levers.
#62
#63
I wear a full face in the rain, and in the winter. I wear a 1/2 helmet most the time. When ever I take a long trip, my full face comes with me, but only gets worn in the rain.
The following 3 users liked this post by SWThomas:
#65
I run with Cardos. We always remove them and carry them. Of course, the mounts are still on the helmets and they cost enough so we also lock the helmets in the truck or tour pak if we are not in familiar territory.
Those little helmet strap locks might keep honest people honest but your best bet is to get them out of sight. Might do a little house-cleaning in the trunk.
#66
#67
HOW TO LOCK A HELMET TO YOUR BREAKOUT[/COLOR][/B]: The lock is from BMW. The bracket is made from 3mm steel and sprayed. The helmet is modified with a 4mm stainless steel cable and that is what is used to lock the helmet to the bike. A knife can't cut the cable ... only [/U][/U][/U]a BIG side-cuter ... but few thieves walk with a BIG side-cutter in their pocket.
#68
How about something like this: https://lidlox.com/?
I use the HD helmet lock with a "T-bar" like this....that I bought at Cycle-Gear.
Ray
Ray
#69
Here are a few selections for helmet locks from HD.
I use the first one every so often and keep two on the bike.
I lock my neotec to the tourpak luggage rack, works great.
They can be found here: http://search.harley-davidson.com/?q=Helmet%20lock
#70
