What do I need to have done
My 2015 Limited has 67,500 miles, and has been basically trouble free, other than a waterpump at 31K miles.
I will be heading out in June for another cross country trip, and was just wondering if I need to be concerned about any mechanical time bombs that I could get fixed now.
i am not concerned about things I can see like tires, drive belt, or normal maintenance like oil changes, but internal stuff that I can't see. .
You say you had a pump at 31K. Was the pump replaced with the OEM original or the newer upgraded version? I'm getting ready to open up my primary and cam chest to inspect the chain tensioners and replace as needed. I don't know what the recommended mileage is for doing stuff like this, but I know they're wear items, so at 51K I decided that's what I would do. Plus, I've got a shift shaft seal leak, so I figured why not address other things while the bike is on the lift.
Fuel filter is probably good idea. When you say primary component inspection, do you mean the clutch plates?.
What is the Cush drive, not sure what that is. thanks
thanks
Originally Posted by 14GuineaPig
2014 FLHTK - @ 130,000 mile - cam chain tensioners, primary chain tensioner, neck bearings, rear brake rotor (wrapped), fork seals (leaking), brake & clutch fluid flush, rear sprocket cushion, front wheel bearings (third set).
That is a great machine! My 15 had the new water pump, and except for brakes, wheel bearings, and tires no other maintenance required. I did have the 110 kit installed at about 35k. Traded at 56k miles. Most trouble free Harley I have ever owned. I traded it a few weeks ago for a 20 FLHTK figuring most of the bugs have been worked out with the M8. I hope I am right.
Had you had any of these things done, besides the front wheel bearings, prior to 130K? I just opened up my primary and the tensioner had very little wear. I'm hoping the cam chain tensioners are the same because I sure wouldn't mind waiting another 80,000 miles to change them. 😉
