clutch and brake fluid flushes: worth it?
Some very useful responses here thanks. Including your's 57!
Not to hijack but do you all get these fluids changed based on time, miles or anything else, color, performance, etc.? I'm at 3 1/2 years, 17K miles, everything looks fine and works perfectly. I'm sure the manual says I should have done it already so what do you all think? Thanks and sorry for the question on your thread OP...
Hi 2015 Limited, 124,000 km (77,000 miles), brakes and clutch perform as new.........is it really worth it to get the DOT 4 flushed? Fluid color looks fine through the windows. I'm a bit of a "ain't broke don't fix" kind of guy. If I do go ahead, what should I expect in terms of labor hours?
I was surprised at how much better my brakes felt afterwards. I thought there was Zero issue with my brakes and they were really good before.
I hear you, my hesitation stems from two things (1) I'm keeping the motorcycle one more season and not looking to spend if there isn't benefit - and yes my safety is on my list of top ten benefits; (2) there are a few stories on the forum about damaged paint, air bubbles and incorrectly torqued covers that make me wish this was something I could do myself, which I can't.
Not really trying to argue here, but yes.
Yes it can indeed suddenly fail. July heat, sitting on the side of a mountain in stop and go traffic and clutch went..... just like that. 2015 Street Glide Special with 2 years 4 months and 21k on the clock. I was very fortunate to be at a spot I could push the bike off the road.
Change the fluid as scheduled...... as much as we don't always like change, this ain't the clutch or brakes or brake fluid from your daddy's old car. I'm generally as big a tightwad as anybody when it comes to stuff, I'm usually skeptical about company recommended schedules as being abit on the greddy side, when it comes to the clutch and brake fluid, I will never risk it again. Mine will be changed at regular intervals.
If you aren't testing your fluid for moisture it does need changed...... Period. How can you safely assume otherwise?
To the OP....change it. You, your loved ones, or some other innocent motorists/pedestrian could be hurt or killed because you want to save $200?
