Completed Install Yaffe Monkey Bars on 2017 CVO Limited
11-18-2017, 08:52 PM
A lot of folks ask about the connection on the throttle grip.
Here you go.....
The grip has an electric plug with two male pins, positive and negative.
It plugs into the two small female holes you see inside the throttle.
11-18-2017, 11:50 PM
Hey Cosmic Razorback it is refreshing to hear someone thank God for his help and blessings. I know everything goes a lot better when we Thank God Before we perform a task and after we're finished. Thank You
The following 4 users liked this post by bowhunter97:
11-23-2017, 06:32 AM
Cosmic Razorback, If you had fairing mounted mirrors do you think the bars would block them?
11-23-2017, 08:40 PM
Quote:
Originally Posted by
Joe J
Yes I am pretty sure they would.
11-24-2017, 03:08 PM
Joe J
I have the same bars. The switch housings would be right smack in the way of the fairing mounted mirrors.
11-26-2017, 08:50 AM
Thank you, for the write up!!
11-26-2017, 04:58 PM
I have the 8" version; You'll get used to them.
11-28-2017, 06:44 AM
Cosmic Razorback
Thanks, I'll probably go with the 12's would be nice to keep my hands behind the fairing but don't want to loose the mirrors.
Couple other questions:
Did you have to de-pin any of the connections?
Do you think there is enough brake & clutch cable for the 12's?
Thanks,
11-28-2017, 06:20 PM
Joe J
Thanks,
The 16's and up have the small connectors. I did not have to de-pin. From what I can see you can do 12's. There is a You Tube showing how to do the stock cables. Do a search and you'll get some good info.
You will like the 12's, I wish I had gone taller already!
11-29-2017, 02:07 AM
Love the Yaffe bars, great choice
