Front Wheel Bearings.
Received 4,614 Likes
How do you know if the bearings are bad? '14 Ultra Limited w/ 17.5K mils on it, everything feels fine, no vibration, only thing I notice is in a turn (50-60 MPH) I get a whistling/whining/buzzing, ONLY in the turn. I'm not sure if the noise is a bearing or tire problem. Years ago we used to jack up our cars and shake the tire in and out, top and bottom, will that work on a Harley? Thank you...
Thanks, I sometimes feel it too but never know, maybe the road is a little uneven, maybe tires, maybe bearings? So many things going on at high speed on 2 wheels it's really hard to pinpoint. I'll try to jack it up as Imold suggested.
They have been using these same bearings and failing since 2008, I don't think they will recall them. They have been revised twice. There are now a couple alternatives to the ABS bearing. The non ABS side is a 6205 2rs available everywhere. SKS, Fafnir, Nachi etc.
I replaced mine at about 24K. I put the bearings in the freezer a few hours before I did the work. They slid in pretty easy with some grease. No press needed.
The center spacer is just that. It doesn't rotate or anything, so a bit of rust on it is no big deal at all. Just looks crappy when ya have the wheel bearings out.
I always clean the rust off that spacer and anything else, and coat all the interior metal parts with grease or anti seize. Sure comes apart easier next time, and have never seen rust in a wheel I put back together. I've had to beat axles out with a sledge hammer on some used bikes, hate doing that. That freezer trick works good, too, I've also done that.
Anyone doing Harley wheel bearings themselves for the first time, do some research. On a single disk wheel, the disk side bearing always goes in first. The second bearing doesn't get pressed in till it stops - that will pre-load the inner races. It just goes in till there's no sideways play in the inner spacer; some bearing tools will do this by design. If the disk brake drags when you put it back together, you may have the spacers in wrong or the bearings. Wheel bearings aren't a "good enough" job, they're a "do it right" right job.
NDRK (11-04-2017)
