2014+ Touring Models This Section Is For Rushmore/2014+ Touring Models Only
Shifter Sticks While Down Shifting
Old 11-17-2017, 10:33 PM
HogPilot54's Avatar
HogPilot54
HogPilot54 is offline
Default Shifter Sticks While Down Shifting
2015 Ultra. When down shifting between 3rd and 2nd and especially between 2 and 1st, by shifter doesn't spring back to the neutral position. It's intermittent and doesn't do it when the motor is off and manipulating the shifting by hand. Did a search here but couldn't find anything. Anyone else had this problem? What's the fix?
Old 11-18-2017, 06:27 AM
EasternSP's Avatar
EasternSP
EasternSP is offline
Received 21,787 Likes on 8,395 Posts
If going to the other gears doesn't present a problem, that says the spring is ok. You might just have a lubrication problem in the linkage.
HogPilot54 (11-18-2017)
Old 11-18-2017, 06:31 AM
Iceman24's Avatar
Iceman24
Iceman24 is offline
Received 2,220 Likes on 1,622 Posts
Have you checked/changed the primary and/or tranny oil lately?
Old 11-18-2017, 11:41 AM
ROCKOUT Rocker Products
ROCKOUT Rocker Products is online now
Sponsor
Received 1,628 Likes on 1,176 Posts
Mine does that if I'm lazy about raising my foot off the lever when downshifting. I do it a few times a ride... I'm a slow learner.
For ROCKOUT information & purchasing please click HERE For all Twin Cams and Evo Big Twins & Sportsters
__________________
NO, they DON'T all do that!
Also on amazon.com...
Old 11-18-2017, 10:03 PM
HogPilot54's Avatar
HogPilot54
Just changed both fluids. Didn't help.
Old 11-19-2017, 07:14 AM
lp's Avatar
lp
lp is online now
Received 2,716 Likes on 1,544 Posts
Like Eastern pointed out, take out and grease your shifter shaft. Pretty common issue.
Old 11-19-2017, 07:48 AM
nytryder's Avatar
nytryder
nytryder is offline
I'll bet that will solve your problem.
Old 11-19-2017, 07:57 AM
nytryder's Avatar
nytryder
nytryder is offline
[double post
Old 11-19-2017, 08:28 AM
tpcowfish's Avatar
tpcowfish
tpcowfish is offline
This, if you don't take foot off completely, it will do it
Old 11-19-2017, 09:23 AM
Ridingon2's Avatar
Ridingon2
Ridingon2 is offline
Default Heel Shifter Eliminator
If you removed your heel shifter and added the shaft cover, check to make sure that you didn't slide the toe shifter to tightly against that cover. I did and mine acted the same as you describe.
Quick Reply: Shifter Sticks While Down Shifting
