2015 FLHTK clutch slipping
Changed fluids for its 15k service. Used Amsoil Primary fluid in the primary. Went on a ride on a cold day (18*F) with a group and stopped to eat. On the way back, on the interstate, it started slipping in 6th. Figured I overfilled or something, and took it easy till I got back to the house. Drained it, got 37 1/2ish ounces out. Refilled with HD formula +. Took it out and it seemed ok, then after it warmed up it began slipping again, 5 and 6.
Sat in the garage for about a week, and decided to drain again, blow out everything with the air compressor, and refill. Figured I'd bleed the M/C while I was at it. Few air bubbles, not much. Refilled to a precise 38oz... still slipping in 5th/6th.
Have the ESP so rode to Fort Bragg HD.. Of course it doesn't cover plates, but if the basket or spring is done? Have an Appt. on Tuesday.
I think it would take me about an hour or so to do it myself, but have never messed with the hydros.
I ride normal to hard. i don't papa it, but don't abuse it. No burnouts or dumping the clutch at shifts/lights.
Anyone else had issues like this? I saw a thread somewhere that had mentioned it.
My frustrations are now vented.
I thought mine was slipping (15 SGS) around 2k miles. I bled it and haven't notice any issues. Some said that if it had air, it wouldn't disengage. Also, I only use Harley Primary oil. I don't see the need for synthetic in the primary.
If mine goes out, I'll definitely be looking at a better clutch than HD. it's a very easy install. The thing that gets me is the cost of the primary gasket. It's like $40. Seems excessive. This is the first place I'd look.
http://www.barnettclutches.com/2015/...lhtc%20l).html
