Fork Oil Substitute
you can use any 10wt for oil, , there are lots of brands, for our application I cant see it making any performance difference, the Ohlins oil I use in my dirtbikes does make a slight difference, but it's very expensive, on our dinosaur HD's I'm sure about anything would be just fine. any bike shop like a cycle gear will have several brands.
If my recollection is correct I believe the stock oil is 5W, the SE (Screamin' Eagle) 10W will increase the compression and rebound damping on the stock forks. You could even go to a 15W if you find the 10W to still not damp well enough. Any of the brands that vizcarmb listed would work just fine. I've used BelRay, Maxima and Honda in the past.
Shock Therapy!
https://www.amsoil.com/shop/by-produ...?code=STMQT-EA
