Wiring harness requirements for multiple accessories (Heated Stuff and CoolFlow)
Currently have a 2017 FLHTK. I'd like to add 3 things:
In the install instructions for the Hammock seat, I see "If another accessory is already using the accessory circuit connector (under the seat, Refer to Figure 4. ), then a Switched Circuit Adapter Harness (part number 70264-94A) is required. And "2017 and later models: Separate purchase of harness extension (Part No. 69201599) is required to locate the accessory circuit connector."
And the last thing for the heated backrest: "If the accessory circuit connector is already in use, a Switched Circuit Adapter Harness (Part No. 70264-94A) is also required."
My question is this, do all 3 items use the same plug in point? Or is it that the CoolFlow uses one and I'll need to split the Seat and Backrest with the optional splitter?
Thanks in advance for the help!
- CoolFlow Fan
- Heated Hammock Seat
- Sun Ray heated Backrest
hallfleming (05-29-2018)
Thanks for the input. Looks like that's a 10 amp fuse on that 69201599 part. I think the Seat, Backrest and Fan would be a total of 11 amp draw but I can't think of a time both the fan and heaters would be on at the same time...
Scarz
2014-2023 Touring Models
171
05-01-2016 08:54 PM
