Runing nav on mute
Runing nav on mute
I'm visual. I dislike the pronounced directions from the GPS. On my 16 RGU when I muted the sound it didn't interupt the music playing. Now here's the question my 17 RGU won't do the same. Anyone know how to accomplish the blank space if you mute the sound for GPS.......It's muted but the where the sound should be it interrupts the music for a the same amount of time. OK thanks in advance for any help
See if this works... Go to the "Home" screen on the BOOM! > then click on "Setup" > then toggle down to and click on "Feedback" and uncheck "Navigation Prompts".
Then click on "Back" > and toggle down to and click on "Navigation Setup" > then click on "Appearance" and uncheck "Audio Information".
Okay
OK I"lltry that
hbsoldier3, you may be correct with just the unchecking of the first one and being done, I do not know for sure. And if I understand you question right, I do not think "Audio Information" is what you see at the bottom of the NAV screen, but I could be wrong. I don't think so because 1) it says "Audio Information" and 2) I think what you see at the bottom of the NAV screen, if you're talking about the information being displayed at the bottom when its navigating, is actually another "field" that you can enable,disable, or even change what is displayed there (like the next street you'll be looking for or something like that). But, with that being said, I am not 100% positive... without going out to the garage and toying with it. which of course now I'm curious so I will be doing shortly lol
Ok, first I have both of the things unchecked that I stated to do above and I do not get audio prompts or music gaps from my navigation operating (just saying as background information). So below is what my screen looks like when mapping to go somewhere. Where it shows turning left in 50 yds and then E Reno St, I am thinking thats what you were referring to, if so, that is actually the "Maneuvers" field and if you toggle to it and click on it, it goes to another screen that shows you basically step by step driving instructions to your destination, and would not be anything to do with "audio information" i don't believe (which I also have disabled anyway). Anyways, hope that helps more than causes confusion lol
hbsoldier3 (06-13-2018)
Audio information shows the music channel and song playing across the bottom of the NAV. Waste of space imo, so I disable it. It also has to be disabled to be able to use both the left and right data fields.
