Help with Boom stage 2 install!!
So I bought the stage 2 speakers and amp, installing it was nowhere near as easy as I thought it would be, so many connectors that WILL plug into each other that shouldn't be.... Anyway, after having to take the fairing cover off the second time and flip some connectors around to get the bike to simply turn on, I got it to turn on and the stereo to function then put back together again.
Now everything works except the controls on the right, none of them, turn signal, start, hazard, nothing. I can't think of anything that would effect those controls, so if any of you have any ideas, please let help me out and throw some advice my way.
Thanks advance!
Thanks advance!
I found the problem. For the next person trying this install yourself, if you’re not installing, or planning to install the rear speakers, do not install the short pigtail that plugs into the BUS on the left side of the head unit. You should have three harnesses left over, the pigtail, the harness that runs to the back of the bike and a Y cable for left and right rear speakers.
Hope this helps someone!
