Stage II: Torque Cam vs power cam
Obviously, different strokes for different folks. I'm not saying I won't go stage 2 on my own rushmore. I'm just trying to point out some facts as well.
It's not about peak either. At best, the Cycle Rama 570 (about the best bolt-in the 103's have) is not going to gain one much over 10/10 anywhere in an RPM range. I'm sure it is worth it to you and that's good, but don't let facts get in the way either. A well-tuned stage 1 Rushmore cam is damn close to the BEST (or near-best) bolt in cam for the 103. Unless you're doing the cam yourself, it's a poor way to gain that IMO.
The OP didn't ask if it was "worth it" to do cams; he asked the difference between the two.
rhuff (09-22-2018)
That's exactly what I said - it's the curve; the boost across the entire RPM range, not just numbers. It's not "worth it" to the majority of people, but to some of us, it absolutely is. You and I aren't talking about different things, nor different "facts"; I think you're arguing subjectively that you don't think it's a good use of funds, and I'm arguing (subjectively) that it is.
I mean, I have a 2003 RKC that is heavily modified. Granted, 107" isn't bike like it used to be tho. But it will lay ruin to most 107's. I'm all about spending money lol
What most people miss here, is this is not apples to apples. The bike with the 570 cams also has a gutted head pipe, a Boyeson intake/air cleaner, and has been dyno tuned with a Power Vision.
If you gutted the head pipe, added the air cleaner, and spend a day on the dyno with a Power Vision on the stock cams bike, the difference is almost nothing.
I have the 570-2 cams, and I'm talking from experience, it's not a significant difference with ONLY A CAM SWAP. My bike is within a couple horsepower of stock cam'd bikes that were tuned with similar intake and exhaust throughout the curve , verified on a Dynojet 250.
I spent the money, and do my own work. If I had to do it again, I would leave the engine together. (this is my touring bike, not hotrod)
Something else not mentioned - adding heads to the equation adds COST to the equation.
My "plan" when I added the cams was that next year, I'd add jugs, pistons, and heads. However, I am so pleased with just the cams, and have a bike with 22,000 miles that burns NO oil, runs fantastic, and hasn't given me a lick of trouble.... I think I may be done.
YMMV.
I will say it again though, most people haven't ridden a properly tuned Rushmore cam bike in comparison to the stage 2. I have. It's just not much of a difference.
Okay, I'm done and out with trying to save some folks coin on this mod.
