2014-2023 Touring Models This Section Is For Rushmore/2014-2023 Touring Models
Bone Dry Coolant Reservoir...HELP
Old 11-02-2018, 11:23 AM
Ohio HD Guy's Avatar
Ohio HD Guy
Ohio HD Guy is offline
Default Bone Dry Coolant Reservoir...HELP
Returned home after riding to Daytona Biketoberfest and back to Ohio, was hot in Daytona, my coolant reservoir was dry on my 15 CVO Road Glide Ultra. Could that be a water pump going bad?
Old 11-02-2018, 11:36 AM
mcouture's Avatar
mcouture
mcouture is offline
The water pump failures seen are electrical in nature.
When my pump failed, I didn't see any difference in coolant level.
How many miles do you have on the bike?
berniemc's Avatar
berniemc
berniemc is offline
If water pump goes out you will get check engine light and temp light.You probably have a small leak somewhere.
Old 11-02-2018, 12:15 PM
Ohio HD Guy
34K miles
Old 11-02-2018, 12:16 PM
Ohio HD Guy
No signs of a leak
Old 11-02-2018, 12:31 PM
hillcountryflt's Avatar
hillcountryflt
hillcountryflt is offline
Fluid has to go somewhere and as the cooling system only cools the exhaust ports, can't imagine it going "down" into the engine. No doubt I am wrong about the nature of the cooling system, but that is my understanding. As such would have to be leaking out. I would refill and start it up and monitor. You do have a service manual, don't you?
Old 11-02-2018, 12:52 PM
Ohio HD Guy
Yes I do have a service manual. I topped the coolant off. I just had it flushed by the dealer prior to going to Biketoberfest. Should of done it myself. The fans were on quite a bit in traffic in Daytona
Old 11-02-2018, 02:58 PM
berniemc's Avatar
berniemc
berniemc is offline
It takes time and patience to refill system correctly. Use your service manual and refill it as it says.
Old 11-02-2018, 03:02 PM
rcn1963's Avatar
rcn1963
rcn1963 is offline
There is a discussion here about a "porous cylinder head" that actually allowed coolant to seep into the cylinder. Apparently, they aerate the metal when casting the heads to make it lighter, and occasionally that creates passages large enough to allow liquid transfer while appearing to maintain pressure. While this seems unlikely...if you really can't find any other leak, this might be worth investigating.
https://www.hdforums.com/forum/new-r...5-ultra-4.html
Old 11-02-2018, 03:54 PM
roadpop's Avatar
roadpop
roadpop is offline
Location: Living 33yrs in Sunny Florida !!! Living the retirement dream....Love it!!!
That might be your answer, maybe dealer rushed it and didn’t fill it correctly..it’s not hard to flush it.,might think about that next time it needs it..If I’m taking a trip,I’m doing the maintenance myself period...
Quick Reply: Bone Dry Coolant Reservoir...HELP
