14 Roadking Winter Project started...
After you paid 460 bucks for the 4 buds I bet you're glad you found some cheap tires huh? Lol...Just kidding...ive had weeks like that not just days. Hey and just a tip for your bracket there, if you fill in those corners with something it will make it alot stronger too...maybe use a cut off piece of the angle. Good luck with the bike
All stripped down except for the heat shields, which I am going to paint also. Everything came off easy except the rear fender. It has 2 nut and fender mounting washers with internal threads in the washer which made it a PITA to remove without removing one of the struts. I scratched the fender a little, but it won't show. I am going to remove one side strut or have someone help me when I go to reinstall the finished fender. My plan is to get everything painted, then start on the engine.
