Lower Fairing Vent Door Slider
Hey folks,
Right side one has come loose. Does not move the vent. 2015 Ultra Limited. Is there a simple fix if someone has experienced this? How hard is it to remove front part of the fairing to access it. I have the service manual....it's not very clear. Trying to avoid taking it to the dealer. Thanks.
Received 2,084 Likes
talkingrock (01-11-2019)
Same here. Since I only open and close them for summer and winter, I haven't tried to figure out what's causing the problem. But, if someone has an easy fix, I'm all ears.
You can get in there, it's a tight fit though. The rod probably just popped off the lever (mine did).
I actually hit both sides of mine with WD40 with a nozzle extension. All of the moving parts are all plastic, but the WD really seemed to help the ease of operation.
I live in Ohio and have to open and close mine quite often.
GalvTexGuy (01-07-2019)
GalvTexGuy (01-08-2019)
