2014-2023 Touring Models This Section Is For Rushmore/2014-2023 Touring Models
Group riding CB Radio question
Old 01-12-2019, 08:18 PM
14GuineaPig's Avatar
14GuineaPig
14GuineaPig is offline
Originally Posted by peddler
Is there a hand held mike that is compatible with '14 and newer Ultra Limiteds. The only one that appears on the Harley site is for bikes '13 and older.
The handheld mic will work with the 2014 Limited but it's use isn't very practical. To use the mic for the CB, you must key the mic (switch on side of mic) while also pressing the handlebar Push to Talk switch. The mic can be used for voice commands (Nav & Phone), to answer/talk on phone, and intercom. It just requires that you press the switch on the side of the mic to talk, No PTT switch needed.
https://www.harley-davidson.com/stor...microphone-kit
I know as far back as 2002, you could listen to the CB thru the fairing spaekers just like the radio, No headset needed. Prior to 2014, the handheld mic worked with just pressing the switch on the mic to talk on the CB. I think things changed with the canbus system on the 2014 & up touring bikes.
Old 01-12-2019, 08:28 PM
FlyingSkeet's Avatar
FlyingSkeet
FlyingSkeet is offline
Just bought the Midland handheld CB for $99 from Amazon also bought the throat Mic,for a adventure bike trip on the haul road to Deadhorse this June.
Old 01-13-2019, 07:05 AM
blueangel73's Avatar
blueangel73
blueangel73 is offline
Details on the throat mic?
I have a midland handheld that I purchased for my last bike and never applied. Looking for a way to use it either via bluetooth or without a need to run tons of wires all over the place. Be nice if there was a way to bluetooth link it to my radio. More for listening then talking.
Old 01-13-2019, 07:17 AM
blueangel73
Is it possible to get something like the Sena SR10 and pair it to the radio via bluetooth. Then use the radio comm system to listen, not so much talk.
Old 01-13-2019, 12:42 PM
FlyingSkeet
I learned about the Throat mic on adventure rider forum it has an corded ear piece, the reviewer said to worked great giving position reports to truckers on the haul road to Deadhorse. Down side if you sing to yourself it ties up the frequency Irritating the others. This is what I read. I have no personal knowledge I just received mine yesterday.
Old 01-13-2019, 01:14 PM
rmc115's Avatar
rmc115
rmc115 is offline
The throat mic is tight if you have a large neck. Not perfectly clear but does work. Mike
Old 01-13-2019, 02:08 PM
wardo5757's Avatar
wardo5757
wardo5757 is offline
Your Sena has a 3.5mm port on it, you can use a handheld CB and plug it into the port on your Sena. If you get the proper cord, you may be able to use two way comms.?.
Circa58 (01-13-2019)
Old 01-13-2019, 02:52 PM
Circa58's Avatar
Circa58
Circa58 is offline
I believe this is possible... thank you!
Old 01-15-2019, 04:35 PM
MilesOfTexas's Avatar
MilesOfTexas
MilesOfTexas is offline
You can use them, but you have to hold the PTT on the handlebars and key the mic at the same time to transmit, lol
Old 01-15-2019, 04:36 PM
MilesOfTexas
If I am not mistaken, the 3.5mm port, aka aux, is input only.
Quick Reply: Group riding CB Radio question
