WHIM new update
I am. I doing that because the application downloaded file is version 1.7.7 and the direct downloaded file is 2.0, of course I want the 2.0.
Yes that is snow it was a chilly ride.
I was having the same problem as you are trying to install the new Whim update. To fix it connect the Whim to your laptop and go to the Windows device list, the WHIM is listed as a serial device, click to update the driver for the device and then start over with the update process. Mine worked like a champ after the driver update. I’m using Windows 10. Hope this helps you out, I was about to give up this did indeed resolve the install/update issue.
