Handlebar Internal Wiring Necessary????
Just curious as I've read up a lot on internal wiring, is it necessary to run the wires through the handlebars if going taller, ie 10"???
Personally I don't mind the external wires it appears the factory does, I assume all go internal just for the cleaner look.
Just curious before I start ordering things I'll need. Thanks for the input..
Who's being an ***? The OP asked about external wiring, I asked how that could be done with the TBW unit as that is already internal. No one being an *** I can see....
Most aftermarket bars are made with the intention of running the wires inside the bar. If the bars do not have the little divit under the switch clamp you'll be drilling either the clamp or the bars to get the wires outside the bar.
Good news is, most of the newer bikes are on canbus which is only two wire instead of a handful. Pretty easy to run those through...
