Boom 6.5 "Error Importing Destination"
Maybe a search on this forum or Google would find it. As it is, the file is far to large to upload here or to try and email it.
grmaximus (04-08-2019)
Now bear in mind that when reverting to Ver. 1.22.0.1 will eliminate any of the "Fixes" that 1.22.0.2 did.
It's a trade off I suppose. Which problems are more of a bother to you.
Anyhow, here's a list of the problems that 1.22.0.2 "Fixed" that reverting to 1.22.0.1 will recreate:
Version: 1.22.0.2 | Size: 842 MB
Date Released: January 16, 2019
Fixes
• Arrival time showed the current time after user deviated from a route.
• Next turn area displayed an arrow with the current street name.
• Special Alpha Jump characters were not displayed.
• The SMS (Short Message Service) repeat button wouldn’t read the message clearly if pressed multiple times before it has completed the readout.
• Audio paused after loading a ringtone.
• VR (Voice Recognition) not working after an ignition cycle.
• Local media preset inconsistent between shutdowns.
• User was unable to search for preferred POI (Point Of Interest) after simulation sleep.
• Constant “Game Start” pop-ups.
• Presets from USB (Universal Serial Bus) drive 1 were still visible on USB drive 2 but not highlighted as available.
• Albums and artists heading were mismatched with list.
• AM (Amplitude Modulation) radio presets not highlighted when USB was unplugged.
• Repeat button NOT enabled on first selection.
• Pre-Cal reset did not delete trails.
• Accept screen appeared for less than 15s after exiting User Off mode.
• Saving or editing emergency number did not work.
• No Siri® pop-up displayed while saving an emergency number.
• Text was missing in the maneuvers list after switching to high contrast mode and then back.
• No initial Siri pop-up initiated.
• Cancel noise was heard when going from VR to Siri.
• Prompt Volume was not updated after changes in Feedback Settings.
• GPS (Global Positioning System) entry changed W(O) to E in Spanish.
• WHIM (Wireless Headset Interface Module) – Low battery pop-up was not shown for passenger headset.
• WHIM – Paired Bluetooth® device name appeared as “Headset”.
• Repeat prompt was not working.
• SiriusXM® weather map did not maintain the default zoom level.
• User off mode enabled navigation prompts.
• VR conflict if Siri was launched from phone at the same time with the radio.
• Saved USB presets for drive 2 were replaced by drive 1 after an ignition cycle.
• USB saved as favorite was not highlighted after an ignition cycle.
• Distance to next action bar disappeared before route recalculation instead of being grayed out.
• “Navigation is not ready” displayed when initiating navigation command to “Find Next Gas Station” via VR.
• Various bug fixes
Fixes
• Various bug fixes
Thanks again Bluehighways.
As a reinforcement to it all, I was at my friends house last night and tried saving an address using his .1 version software on his bike.
(I had actually did the update for him last year to the .1 software as his was much more out of date)
I was able to save the address no problem using the same procedure just as you have reported.
Caution VENTING about to follow;
Harley Davidson get your act together!!! You are not suppose to LOSE functionality with software upgrades/upversions!!! You are suppose to gain features and correct issues.
I worked for a technical company for more than 25 years and when you provide new software you are supposed to check all functions post upgrade.
Their is something called Project Management that appears to be missing or substandard with this Boom software/Harley Davidson co.
I find it impossible to believe HD doesn't know this simple function doesn't work post software upgrade, it's been out for 2 months plus.
Keep it up Harley Davidson, and you'll be out of business within 25 years...
Rant over....
I feel better already
Rant over....
Do you use the gps a lot, importing routes with waypoints and such? If you do, all the route information is being saved in "Saved." This will fill the memory of the POS up and you will not be able to save anything more. I'm sure you have already deleted all the stale routes in "Trips" but do check out all the garbage in The Saved. For a few dollars why would H-D go to some 2nd rate Hungarian map maker instead of Garmin??
00HDrider (10-11-2020)
jellopis (08-13-2021)
Bonjour from Québec. Here is my comment :
A release date is written on each swdl_boombox_6.5GT.iso file.
I made 3 download at different dates
and I noticed a different released dates
for the same version 1.22.0.2
2019 Feb. 02 Download : swdl_boombox_6.5GT.iso Release 2019-01-17 12 :52h
2019 Mar. 19 Download : swdl_boombox_6.5GT.iso Release 2019-01-16 10 :00 h
2019 Apr. 27 Download : swdl_boombox_6.5GT.iso Release 2019-01-16 10 :00 h
Surprisingly, sometime after the Feb. 02 download,
the release date has been advanced form Jan. 17 to Jan. 16?
I am not interested to make an error comparative study about that!
All these files are for the first time simplified, being without sub-directory,
but none of these files has a version number specified with it.
I guess we are better to wait for the next official update, to maybe (?) find out…
Bonne route, Gilles
Bonne route, Gilles
Ell Cee (07-23-2019)
