Mesh wire weave for bar wiring
Just wanted to find out if anyone has used mesh wire weave to help pull thru wiring on their bar swaps. I've seen where KST supplies a piece of this material and I was hoping to find the rough diameter that I could order. I sent KST an e-mail the other day but I see they only work m-thurs. Any help would be appreciated since I'll be swapping over to a set of Monkey Sport Bars and I'll probably remove the harley stock sheathing and replace with some heat shrink to make the install just a bit easier. A few other members have mentioned this trick but just wanted to check out another option. Thanks
Received 39,246 Likes
Shrink-tube tends to get stiff after it cools.
Thanks I did find that on amazon before but I was hoping to get a diameter needed from KST before ordering. The heat shrink was just to make the entire bundle smaller than using the stock harley sheathing. A couple members had mentioned using this on their bar swaps to make it easier pulling the wires thru.
