Valve / Top End Noise
I have no idea; however, I do know it seems to work fine from 37-115 degrees where I live.
Give it try, you might like it. My motor didn't make any unusual noise with Mobil 1 either. However, the valve train noise is significantly reduced with the Spectro dino. Rockout Rocker introduced me to Spectro, and my claim is he knows quite a bit more about top end noise than me, YMMV.
Ask the people who made the cams if they have lead ramps before the lift. Factory cams have this. High performance may not. Cams have the base circle which the lifter runs on and in theory, is the center of the lifter total travel with the valve shut. Lifters bleed off at a calibrated bleed. So as the valve is opened, and runs up the ramp, there is some bleed since it is pushing against the valve spring. Just left the setting, valve spring will bleed a lifter. If it did not work that way, the lifter could hold valve off the seat.
What you may be hearing is that little bleed off and clearance when cam hits lifter to open. (stock has a very slight ramp before the mountain.)
Since you wanted high-performance cams, they come with a cost. Most just accept the cost.
Doubt its the oil. Open exhaust will also sound like valve peck. You can hear and real valve peck. A mechanic stethoscope will rule out the sound of the valves opening and closing in the pipes.
The following 2 users liked this post by GalvTexGuy:
Bafflingbs (04-25-2019),
rusty289 (04-24-2019)
I guess what I was trying to imply was that running a heavier oil is just masking the underlying mechanical issues. It seems todd-67 and RIPSAW have eloquently spoken to this in their recent posts. All due respect to Mr. ROCKOUT Rocker Products, but I found it surprising that he would think changing oil is going to solve the OP's top end noise issue, especially after installing his product. In my opinion, it ain't the oil.
Here's the thing with oil...
It's not just that it's thicker. As a rule, in practically every case dino oil will make an engine run quieter than syn. Dino oil seems to have a cushioning effect, I'll leave it up to the scientists to explain why. Of all the oils I've tested Spectro seems to be the best when it comes to noise. Others (including outside of this thread) repeat the same findings.
I don't sell Spectro or have anything to do with the company, I just recommend what I find works
For ROCKOUT information & purchasing please click HERE For all Twin Cams and Evo Big Twins & Sportsters
__________________
NO, they DON'T all do that!
Also on amazon.com...
The following 5 users liked this post by ROCKOUT Rocker Products:
1 2 many (05-02-2019),
gigihurt (05-01-2019),
Greezey Rider (05-09-2019),
H-D_Doug (05-01-2019),
rusty289 (04-25-2019)
Ask the people who made the cams if they have leed ramps before the lift. Factory cams have this. High performance may not. Cams have the base circle which the lifter runs on and in theory, is the center of the lifter total travel with the valve shut. Lifters bleed off at a calibrated bleed. So as the valve is opened, and runs up the ramp, there is some bleed since it is pushing against the valve spring. Just left the setting, valve spring will bleed a lifter. If it did not work that way, the lifter could hold valve off the seat.
I have been looking at oil spec today and the viscosity of the synthetics when compared to dino are unbelievably different! They give viscosities at 212 ºF or 100 ºC and for example Amsoil shows a viscosity of 18.5 at that temperature while the Spectro stuff being talked about has a viscosity of 93 at the same temperature! The synthetics are like water when hot! That has to have some bearing on noise wouldn't you think?
I get the argument that synthetics are engineered and designed and all that but these numbers prove my theory, and if the HD 360 dino oil is anywhere near what Spectro is I'm sure I'll see some similar numbers though I haven't been able to find any specs on it anywhere go figure with Harley.
