New to touring bikes - 3 hole oil change due
As the title says I’m new to touring bikes, have ridden Sportster my entire life and now that I have started taking more trips I decided to upgrade.
Picked up a used 2015 SGS a few weeks ago with about 4500 miles on it. She’s at about 5,200 now. Enjoying every bit! I planned on doing the full 3 hole fluid change as part of her 5,000 mile service. However in these ~700 miles I have noticed one thing I would like to try to address it with this fluid change. Hopefully y’all can help me answer these questions
- 1st gear whine. From what I can tell it’s due to the cut of the gears in 1st and 5th. I’ve read that Redline Shockproof will quiet her down. Is there any compatibility issue if I drain and use this if some old Harley fluid is still left in there?
- Never owned a bike before with a hydraulic clutch - is there anything special I have to do with the reservoir up top when changing the fluid from assumably Harley Davidson to a newer on? I don’t think the two systems are necessarily fluid sharing but I want to be sure.
- Engine oil - I assume it is the Harley Dino oil. I plan to go amsoil v twin full syn or possibly Mobil one. Has anyone ran this and what are your thoughts? Will be using a Harley oil filter
My big concern is using specific fluid for the different holes. While Harley calls out that syn 3 is good for everyone I have to think that a specific fluid is actually better than a one stop shop. Heard a lot about redline but never used it.
Anything helps! Thanks!
Redline shockproof should help to quiet your tranny a bit has for the rest use what you can afford oils are about the same in quality i have been using the Syn 3 oil in all three holes but this time around i am going to look some different and a little bit cheaper. Don't get me wrong HD makes good stuff but your going to pay for it.
Bob the Oil Guy
https://www.bobistheoilguy.com/
Bob the Oil Guy
astolt12 (04-29-2019)
GalvTexGuy (04-29-2019)
Received 1,934 Likes
Hope this helps.
The following 2 users liked this post by HKMark23:
astolt12 (04-29-2019),
hbsoldier3 (04-29-2019)
For the hydraulic clutch? Like what? It uses the same brake fluid that the brakes use. Not much to do there other then change the fluid when you think it needs it. As for gear whine, try different lubes in your primary and transmission.
I've been using Red Line in all three holes since my first service. Engine, primary and transmission are still doing their respective jobs.
Use a good SYN for the engine.
Use a Harley Formula for the Primary.
Use Redline or Belray for the tranny.
Ask Service Dept about brake fluid Clutch.
