Wiring Baja designs S2 pros
Wth does this mean
You might want to let a dealer tech wire your lights. It's pretty obvious from comments there is a lot of misunderstanding about the factory console switches. Or you can look this up:
Note - Various options are available to purchase only those parts you need. I referenced this so you can get a better idea of how things work together. That harness includes the relay for circuits requiring more than 2 amps DC. It plugs into the ACC connector under the left side cover, just below the holder for the battery tender wire/connector (you can find this in your owner manual),
nuljas23 (06-28-2019)
No I didn’t realize the factory switches were an integrated system, my 09 street glide I added auxiliary lights to wasn’t like that. I don’t need it to function like a factory light switch as I just want the switch to arm the lights but them to come on with the high beams when the switch is in the on position, would I still want to use a factory setup like this to accomplish that? I have looked at them but didn’t think that would be the way to go. I guess it wouldn’t hurt having extra switches but I don’t know what I’d add down the road. Thanks for the help.
the last place I’d let do any custom wiring on my bike is the dealer, i doubt they’d even be willing to do what I’m after.
You can avoid the console switch assembly, CANbus wiring & BCM controlled output completely & add direct wiring by using this:
switch
housing
nuljas23 (07-03-2019)
