Wiring Baja designs S2 pros
Wiring is not one of my strong points. I ordered a pair of Baja designs S2 pros that I’m going to mount on my crash bar after I design a clean mount for my buddy to machine. They’re going on my 18 SGS that has a vision x headlight. I’d like to use a factory auxiliary switch to “arm” the lights so they’re activated with the high beam switch. So auxiliary switch off, headlight functions normal, auxiliary switch on and the S2 lights come on with the high beams. If someone could help me accomplish this I’d appreciate it.
They’re impressive for sure, I have a ton of Baja designs lights on my trucks. I drive a long ways in the dark on very rural roads they really help me see anything that’s out there. Plus the 5k color helps keep my eyes from fatiguing after extended use. I wish other led lighting companies used 5k or less instead of 6k and higher
Got the lights in today. Cell phone pics aren’t the best for showing light output but this does a good job at how bright these things are. This is one Baja designs S2 pro, im mounting one on each side of the crash bar. These are combo pattern so I’ll put the spot toward the middle of the bike and be flood to the outside
I think this is how I’m going to mount them with a custom machined clamp mount, or maybe I’ll just weld two tabs and have it re powdercoated
