Waterpump Clamps
Waterpump Clamps
Has anyone bought and used the spring style clamps on all the connections when installing the new updated pump ? The kit has some crimp style clamps that i do not care for. Besides if using the spring style you can disassemble if you need to replace a radiator or some other part. I believe the updated pump kit only uses the spring style on the pump connections.
Either that or i may use worm style clamps which i don't care much for either.
I was thinking of just buying the spring type clamps right from the dealer. I would think they would stock these as they are stock replacement on some of the locations on the pump. They should just use the spring type in all locations, but that would let people do it at home instead of having to bring in to the dealer because of the special tool needed to crimp them.
