2014-2023 Touring Models This Section Is For Rushmore/2014-2023 Touring Models
Rear fender license plate bracket
Old 06-24-2019, 09:19 AM
RagmanZL's Avatar
RagmanZL
RagmanZL is offline
Default Rear fender license plate bracket
I have read through other posts regarding this issue but most of them were pretty old so I was wondering if anyone came up with a new solution.
2014 Limited, installed Tour Pak detahc kit and used license plate bracket that came with kit. Didnt like the way it stood up so I followed a you toobers video and snapped off the tabs to rotate the bracket to put it below the tailight.
This required me to buy a new taillight with a bottom window and the end result looked the way I wanted so I was happy.
Problem is that I cannot get the bracket conform to the curve under the taillight so it rattles.
At first I didnt notice but when I finally did, now thats all I hear.
Looking to put a curved license plate bracket, under the tailight without requiring me to drill holes. Wont need a light because I bought the bottom window taillight.
Has anyone found anything that works?
Thanks.
Old 06-24-2019, 09:46 AM
GalvTexGuy's Avatar
GalvTexGuy
GalvTexGuy is offline
Received 3,942 Likes on 2,164 Posts
When I installed the detachable kit, I ended up bending the license plate bracket so it lays down at the same angle as the rear of the saddlebags. It was better than the billboard look.
I haven't seen anything new in that department. Can you post a photo of what your setup looks like? Also, whose taillight with the bottom window did you use?
Old 06-24-2019, 10:28 AM
Schulzy's Avatar
Schulzy
Schulzy is offline
Native Baggers Plate Relocator
Old 06-24-2019, 10:32 AM
RagmanZL's Avatar
RagmanZL
RagmanZL is offline
This is the way its currently set up. I purchased Part #: 215495 Drag Specialties Red Laydown Taillight Lens w/Bottom Tag Window - 2010-0783
1Part #: 22552 Bluhm Enterprises 3157 Dual Function LED Taillight Bulb - BL-3157360W
GalvTexGuy (06-24-2019)
Old 06-24-2019, 06:51 PM
Jjpmach1's Avatar
Jjpmach1
Jjpmach1 is offline
I just went ahead and did it the right way. Bought the bracket and took it to my friendly neighborhood body shop for him to drill the holes and paint it. Tried messing around like you did. Wasn’t worth it.
Old 06-24-2019, 10:15 PM
thefirstbigone's Avatar
thefirstbigone
thefirstbigone is offline
I did something similar then I placed an Air Wing luggage rack over it to make it less noticeable. I’m happy with the results.
Old 06-26-2019, 10:37 PM
merdahl's Avatar
merdahl
merdahl is offline
What is the part number for the license plate mount?
Old 07-14-2019, 08:54 PM
RagmanZL's Avatar
RagmanZL
RagmanZL is offline
What bracket did u buy?
Old 07-15-2019, 06:05 AM
GUAC's Avatar
GUAC
GUAC is offline
Gathering parts to do the tour pak detach on my '14.
Have you looked into the softbrake bracket option?
Old 07-15-2019, 08:43 AM
RagmanZL's Avatar
RagmanZL
RagmanZL is offline
I have been looking at posts and this may be an option if I can figure out the exact part number that will work.
Quick Reply: Rear fender license plate bracket
