EITMS revisited.....
My statement was pointed at the fact that my truck drops half of it's cylinders while under load, on the highway, and the bike does it at idle ONLY. And then only when AAT is over 80°, and engine temp is at whatever point they prescribed.
I haven't tried this yet on my 14 SGS, but this is a procedure that was noted when this Engine Temperature Idle Management System was applied back in 2008. I do not believe this procedure has been altered since then.
Vehicles delivered from the factory with ETIMS disabled, the ETIMS can be enabled or disabled by the rider by using the following procedure.
My SGS was disable from the factory when delivered to the dealer. My dealer enabled it before I picked it up per my sales person.
1. TURN THE IGNTION SWITCH TO THE ON POSITION (DO NOT START THE MOTORCYCLE).
2. PUSH THE THROTTLE TO ROLL-OFF POSITION AND HOLD.
3. AFTER APPROXIMATELY 3 SECONDS, THE CRUISE CONTROL INICATOR LAMP WILL EITHER FLASH GREEN (ETIMS ENABLED) (OR RED ETIMS DISABLED).
4. REPEAT THE PROCEDURE AS NEEDED TO ENABLE OR DISABLE ETIMS.
I was trying to figure it out myself and I found this video
, sorry dont know how to post videos or links yethttp://https://www.youtube.com/watch?v=fuU-vXc-gIg
